removing blower motor from URS6
  • K7ERG
    • 1711
    Any pointers in removing the blower motor from a URS6 with Aircon???
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • quattro20v
    • Jul 2007
    • 173
    Not an fast and easy job, takes the hole evening. You have to pull the heaterbox out from the car.
    That is if you don't want to saw the plastic with dremler or similar tool. It will destroy the box. You will need to use some glue or something to put it back together.
    Now quattro less, my urs4 stolen 13.8
    • K7ERG
      • 1711
      Need to keep it whole. Is there any securing bolts holding it down or is it just stuck down.
      Craig
      07947385043
      • quattro20v
        • Jul 2007
        • 173
        It is glued to the body, you have to dismantle the wiperarms and some stuff (heater ducting)from inside to have it removed.
        • K7ERG
          • 1711
          I have the wiper motor off.
          Ok so need to remove the inside ducting first.
          07947385043
          • quattro20v
            • Jul 2007
            • 173
            Take both lower footwell trims off, there is 90 degree ducting on both sides what you have to remove.
            Then you have to pull two connectors behind the center console, you shold see them if you remove your stereo. They are blue and red colored.
            It's easyer to take the center consol off to have more room but you can do it without taking it off if you have small hands.
            There is also a flat rubber hose bottom of the heater housing what you have to pull off.
            On the engine bay take everything away on top of the housing and under the wiper arms.
            You need all the room you can have.
            Relaise the rubber hose between the aircon and the heater. Take the cooling hoses off.
            I pulled the heaterhousing off with a crowbar you need to use some force to get it out. I started to pull it off from the side you have the relay box. Top corner.
            I can send you some pictures if you give your e-mail address to me. PM me or something
            I also changed the heater matrix as precaution cos it's the same thing again if you blow the matrix the next week.
            • K7ERG
              • 1711
              PM sent
              07947385043
              • quattro20v
                • Jul 2007
                • 173
                If you need more pictures i have like 200 more from this job. Just ask.
                • K7ERG
                  • 1711
                  cool will do
                  Craig
                  07947385043
                  • Graham
                    • 1622
                    Is this the same proceedure for the S2 coupe with aircon, my motor howls--bearings fooked.
                    Graham
