Replacing engine coolant
  • Dingo
    • Jan 2008
    • 229
    I've dropped the coolant on my car and flushed it out sevelal times, I know it takes G12 plus, (60% water 40% antifreeze) but how many bottles (1.5 ltr) do I add to get this ratio as I carnt find anywhere how much water the system holds.
  • Nuvo
    • Nov 2003
    • 3826
    You'll need two bottles as the systems holds ~7 litres.
    • Dingo
      • Jan 2008
      • 229
      Great, thanks for the help
      • rj scotty
        • May 2006
        • 2195
        Fill the matrix with a hose pipe first, no air locks then.
        cheers
        rich
        BUT I DON'T WANT A NEW CAR!
        1995 S2 Avant, Volcano Black
        • Henkjan
          • 1705
          many chances for airlocks, keep a very good eye on the coolant level the next months
          • ChrisG
            • Jan 2005
            • 68
            Having just done this on my 80 Sport ( B2 - DZ engine) I can vouch for how easy it is to get locks......
            Last time I replaced rad and had no problems this time ( two weeks ago - stat & clean out)was dreadful.
            Looks as if I also have a tired water pump that probably did no favours either ! I must have spent about 4 hours+ trying to sort out, in the freezing cold of course
