Noisy AC pump????
  • rallyejames
    • Apr 2008
    • 129
    Noisy AC pump????
    Hi peeps....dont know if anyone can help but have found my ac pump has been getting a little noisy
    Removed the v belt to find either the bearings or the clutch is on its way out.Spin the pulley and you get a definate grinding noise.
    Is there a repair kit available? or do i need to find a Ac wizard?
    Have left the v belt off at the mo...alot quiter...but need to get it sorted asap.
    Can anyone point me in the right direction?
    Many thanks James
  • A80Avant
    • 10873
    • Country: Greece
    mine was like that when the wrong amount of oil/freon was used.After i had it recharghed eveyrthing went back to normal. Either way it could be that the pump is giving up after all these years.I see that the ebay.de has ac pumps quite cheap.
    • GT500
      • Jun 2006
      • 2181
      Many thanks James
      I might have a spare! i'll have a look...
      Rob..
      87 UR 20v ABY
      97 S6 Avant
      • rallyejames
        • Apr 2008
        • 129
        Thank you........
        • s2driveruk
          • 12696
          depending which model 3b/aby i have one sat on the bench which i think was absolutely fine after all lol
          1992 3b S2 Coupe
          • rallyejames
            • Apr 2008
            • 129
            sorry sould have said...for 'ADU'
            Thanks James
