need climate control wireing
  • aronmatic2
    • 2129
    • Country: Hungary
    i need rs2 or 93- audi 80 automatic climate control(newer 2 window) wireing. i am looking for all of them, included inner and from the engine bay.
    if somebody have it, dont hesitate to shoot me a pm.
    thanks.
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
  • johne
    • Apr 2007
    • 1406
    thanks.
    It's all on www.S2central.net
    You need sheet 75 of the wiring diagrams.
    John
    • aronmatic2
      • 2129
      • Country: Hungary
      John
      are you kidding? do you know, how much work is it?
      • javispa
        • Jul 2007
        • 292
        • Country: Spain
        Aron, do you want to install the newer climate control in a 3B car? I have the control unit and would like to do the same.
        Cheers.
        Audi Coupé S2 '92 -- VW Golf 2 GTI '91 (v2) -- Renault 4 TL '84 -- Audi 100 2,3E '92 (Dad's) -- Suzuki SV 650 S '08
        • aronmatic2
          • 2129
          • Country: Hungary
          yes. my car is 3b without ac. now i collected everything.
            It's pretty simple process on LHD... Though you will need to get dashboard out and disconnect water pipes and the aircon pipes so that the heater/aircon unit can be removed.
            The LHD climate controlled heater/aircon assembly is different from manual aircon as there are numerous electrically controlled flaps (instead of cables). With the right head unit (from a B3/B4 vehicle) it is easy to code this for S2 - and the wiring loom from B3/B4 is plug and play. The hardest bit is the roof temp sensor as thats a lot of hassle to fit up at the sunroof switch - but you could easily locate it on dashboard instead.
            I am looking to do the climate conversion on my S2 Coupe - but its a bit more complex as a RHD car - some parts from RHD B5 required.
              Got any more details on the plug and play wiring?
                No detail required really - if you have the climate loom from an LHD B3/B4 then it is plain sailing by following the schematic... A LHD or RHD climate loom from B5 can also be used with minor mods...
                Hardest bit in all of this conversion for an RHD B3/B4 is the graft involved to swap out the central HVAC section.
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  http://cgi.ebay.de/Klimaautomatik-Au...d=p3286.c0.m14
                  aron here you are
                  • javispa
                    • Jul 2007
                    • 292
                    • Country: Spain
                    My 3B has electronic climate control (quite common in Spain as our weather is much warmer), but the old unit. What I would like is to install the new one. My worries were if I had to change the loom and the aircon radiator and pipes. If it is easy I will try it in a while.
                    Thanks Paul.
                    Cheers.
                      Thanks Paul.
                      Cheers.
                      Pls post a pic of your cars head-unit just so I can be sure which type it is... I think all you need is new style head-unit and loom - no need to disturb aircon pipes or heater matrix - but I'd have to check schematics first.
                        Then again - if your car is older than 8B-N-012000 then it will be oddball climatronic which uses lots of vacuum controls - different loom, different actuators and different heater housings
                          What spawny git sniped that loom off me on eBay with two seconds to go ?
                          I was doing a refresh at about 5s to go just to be 100% sure - the refresh paused a bit, then it was over and I thought I had for 15 Euro. My max bid of 51.50 was sniped in the last two seconds - **** **** ****** ***** etc
                            What are the mods that are required to the B5 loom?
                            Anyone know of a climate loom from an LHD B3/B4 going for sale?
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              there is usually a German ebayer(shop) who sells the whole unit uncluding the wires on a price no more than 150euros or something
