Just Swapped from Auto to Manual CC
  • Ruffiano
    • Sep 2007
    • 1458
    For my project, I figured while the HVAC Box was out for re wiring the car I should do some work on it, I followed Skulls post and re-covered all of my flaps, I also swapped the box from old style Auto, to new style Manual. I have had manual CC in these cars and prefer it to the auto, I also have the new auto in my URS4, but don't really care for it either. So I had a quick question about the vacuum arrangement, here is a picture:
    That is now the only vacuum connection on it, I'm assuming that the black vacuum line from the engine bay hooks up to the gold part, I'm guessing the one hose goes to the recirculate flap (how i have it hooked up in the photo), the one I'm not sure about is that other hose... Where does it go? Cheers
  • Ruffiano
    • Sep 2007
    • 1458
    no one has manual climate control?
    • johne
      • Apr 2007
      • 1406
      The other hose goes to your vacuum reservoir which is linked to the inlet manifold via a one way valve.
      John
      • Josh-stateside
        • 741
        nothing goes to nipple on the right and the hose on the left goes to the check valve off the vacuum line to the vacuum canister. It goes on the back side of the check valve if your cars has that and should because of the rear diff if i remember correctly.
        • Ruffiano
          • Sep 2007
          • 1458
          Got it, thanks!
