heater fan not working- resistor pack?
  • andyg plym
    • Nov 2006
    • 4646
    hi guys i have a problem with my heater. the heater will only work on setting number 4, and when you put it on that its as if its only on setting 1.
    today i went behind the glovebox and went to replace the resistor pack as i got a spare from Spink, but unfortunately it was the wrong one.
    i disconnected the wires and the fan still came on
    i had heard that it could be the blue coloured plate under the front bumper, so i looked under there to find it all gunked up and mancky
    Anyone have a clue which one the problem is with?
  • andyg plym
    • Nov 2006
    • 4646
    car is a late 95 avant with aircon
    • K Simmonds
      • Dec 2007
      • 7633
      The blue coloured plate under the bumper is the resistor for the radiator fan and is not linked to the interior fan.
      Odds on it's the resistor plate on the blower itself, the aircon and non aircon ones are different.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • andyg plym
        • Nov 2006
        • 4646
        yeah mine seems to be a white one, just got to try finding one now
        • johne
          • Apr 2007
          • 1406
          Most likely the thermal fuse - it's the silver item that runs across the top of the resistors. Check it for continuity. You can get a replacement from Maplins but be very careful if you solder it in !!
          John
