main rad fan cfm rate, data needed
  • s2driveruk
    replied
    Gazza - got ay details on the pacet you are running and how you wired it...is it using the feeds for the existing oem unit or did you use a separate thermoswitch etc?
    David
  • Dirtylouie
    replied
    thanks for help found a possibility to ship 1570cfm 1.7inch thick =)
  • GazzaG60
    replied
    try summitracing.com if its american. they got loads of stuff.
  • Dirtylouie
    replied
    Originally posted by GazzaG60
    i got mine from demon theives IIRC
    demon tweaks?
    too thick, not powerful enough
  • GazzaG60
    replied
  • Dirtylouie
    replied
    the pro's can be thicker than the clubman IIRC its about cfm.
    looks like you have a good solution already though to me.
    i wish i had it at my hands. It's just one US company which produces these units, but they do not ship overseas
  • GazzaG60
    replied
  • Dirtylouie
    replied
    good so you have imo got it correct.
    pacet pro. they flow better than the clubman ones but cost more. they change the design from time to time though.
    like i say, 1 small one if space is an issue and one larger works better again.
    err.. checked them... to thick. thinnest is 3 inch, and with a front rad only 2" can be fitted =(
  • GazzaG60
    replied
  • Dirtylouie
    replied
    think i have misled in the type i have done. sorry
    the fans on the ace/6a are nice slim ones from the factory. the ones supplied are 850cfm from audi i think you said. the ones we used as they were the same size were pacet pro. deisgned to flow more they did about 1100 each.
    im no expert in flow rates. id do as you did. it may be that id replace the second small fan with a bigger unit for max efficiency in traffic.
    now i see... you got it wrong, we use a radiator from ACE, fans are aftermarket slim ones, universal model. set on the outer side, reversable, used as a pusher. BTW Which ones have you used? 1100 cfm sounds attractive
  • GazzaG60
    replied
  • Dirtylouie
    replied
    ah ok.
    i know the rad. got one on the shelf. yes they will be plenty. they are the size we used on a couple of subaru's 2 fans. think 1100cfm each pacets. its a pretty big rad that one.
    the s2 fan is bigger due to the location of the rad thats all.
    another option if you are worried on the cooling is fit 1 biggter unit at the end of the rad closest to the thermostat flow wise.
    He-he Rad is original unit from i4 16V Audi engine (ACE) btw it's the same that is used for ABK mit klima It's not that big actually, and flow rate for the fan, claimed by manufacturer is only 850 cfm. We plan to use 2 of these,
    How come you calculate 1100? Is it more complicated, then just multiplying it by 2? (850x2=1700)
  • GazzaG60
    replied
    ah ok.
  • Dirtylouie
    replied
    corrado engine was a supercharged 8v running a 65mm pulley. its warmer than an s2 engine with a radiator about 1/2 the size.
    the shroud is worth about 30% IIRC. without it you cool one spot. the pacet will run at similar noise but flow more air.
    what makes you think that an S2 will be hotter or more powerful?
    ive already been down this road and know it works. im thinking of doing the same as now my fan is drawing a little to heavy and it can be felt when it kicks in.
    decide whether you want a puller or pusher. IIRC pusher is more efficient. 1168cfm would suck a rag to the front of the rad pulling through it.
    it's a little bit more sophisticated, then just replacing a fan.
    i'm after full AAN conversion, including intake and ACE front rad with a dual 10" slim pusher fan, 850 cfm each.
    Should work with these imo
  • GazzaG60
    replied
    typo 1168 meant 1668.
