A/c
  • Jamie
    • Nov 2003
    • 83
    A/c
    I've had someone out to charge up the ac and test for leaks. Turns out there is a relatively large hole in the low pressure liquid line. This is the aluminium pipe which runs from the compressor to the expansion valve (compressor side). The quote for a new VAG part is enough, but labour is pretty hefty aswell. Can anyone tell me the following:-
    a) Anyone here specialise in ac?
    b) Quote on a new pipe, or where can I get one?
    c) Could I get the pipe brazed instead of replacing, hence saving on the cost of the part, but more importantly the labour!
    Travelling abroad in 4 weeks - would be nice to keep cool!
    Ta
    J
  • audiman
    • 4827
    Do you mean the pipe that runs under the engine??
    I had a pipe repaired on my car about a year ago. Cost of new pipe was 120 quid and the repair was done for about 10!!
    The pipe will only be aval. from Audi (or VAGPARTS). Buy a pipe and fit it yourself. Or get a garage to fit it for you. Use new 'o' rings and then get it gassed up.
    Condensor(rad) to compressor pipe right?
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Jamie
      • Nov 2003
      • 83
      Tom
      It runs vertically from condensor below up to top of engine (heat reflector around it) and has a 90 deg bend, joins another pipe and runs horizontally along rear of engine bay. The labour costs ive been quoted amount to £300 + - whatever! Wish I had a part no. Good idea thou, I could get a garage to fit the pipe at a much lower cost.
      J
      • audiman
        • 4827
        300 quid!! LOL. Nice one Audi. I'll do it for that!!
        Audi UR Quattro
        • Jamie
          • Nov 2003
          • 83
          Its actualy an ac specialist (those that come out to you and gas up for £40.
          J
