Auto climate control in an URS6
  • rizzono1
    • Jul 2009
    • 127
    My air blower wont demist the windscreen anymore and I am only getting air though the passenger vents no matter what setting i select. Any ideas what I should do before iI start ripping everything to bits.
  • prj
    • Mar 2010
    • 6308
    I don't think you really have a choice other than taking it to bits.
    However, I'd read the error codes from the climate control first. It should tell you what is wrong in this case.
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      You have 2 problems.
      1: is the return spring from the recirculation flap broken..this gives you the demist problem.
      2: flaps motor damaged or blocked.
      As Prj said...check the codes first and the return spring...under the glovebox!
      Regards!
      • rizzono1
        • Jul 2009
        • 127
        Thanks for the info, how do you check the error codes from the climate control.
        • johne
          • Apr 2007
          • 1406
          See:
          AudiWorld was created to maintain the most comprehensive collection of Audi information anywhere in the world. Site includes Forum, Tech, Polls, Gallery, and more!
          Also VagCom.
          This may help as well,
          John
          • rizzono1
            • Jul 2009
            • 127
            Thanks for the info, I will have a look at it over the christmas holidays.
            • mcandmar
              • Apr 2004
              • 5118
              Ours has a similar problem, and when ever it logs a problem with a positioning motor it seems to disable it. However if you clear the code and run the output tests a few times to exercise the motors it will come back to life and work fine for a while. I just need to work out which part it needs and how to fit it without removing the dash...
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
