Bought an S2 and found the auxillary radiator has been removed and hose blanked off, can someone explain why this may have been done???
auxillary Radiator Removed ???
Makes access to the front of the engine a lot better, saves weight and in our climate at least engine will actually run a little cooler due to increased air flow.
Many of us have done this mod and it's one I would recommend.
cheers
richsigpic
BUT I DON'T WANT A NEW CAR!
1995 S2 Avant, Volcano Black
2003 VW T4 long nose X pack, (has become project) -
There you go !
your not alone
2003 VW T4 long nose X pack, (has become project)Comment
Also the previous owner may have found that the old rad was rotten and starting to weep, that's what has happened to mine im going to blank it tomorrow and do a coolant change at the same time!Comment
You found the best place to learn
