3B Aircon Pressure
  • Tonks4x4
    • Nov 2005
    • 3062
    3B Aircon Pressure
    I have a quick question about the gas pressure on my aircon system. The clutch was not pulling in on my aircon compressor, I have traced it down to the fact that the Low Pressure Switch is not allowing the aircon unit to trigger. Once the switch is bypassed everything appears to work. I have changed the switch but it still does work. I had it regassed tonight but just need to know what pressure should be in the system to operate the switch.
    ta in advance....
    Audi Nut!!!
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    What colour is the switch housing?
    SS
    • johne
      • Apr 2007
      • 1406
      Around 3 bar, 45 psi.
      Don't bypass the low pressure switch for long, it's crucial to the operation of the aircon. If it's not closing it means there's not enough R134a in your system and remember the compressor is inhibited at temperatures below approx. 4 degree C.
      John
      • rj scotty
        • May 2006
        • 2195
        Don't know the pressure as it is very temperature dependent your probably looking at a high and low acceptable figure. I believe the system needs about 8KG of refrigerant/oil.
        Jonhe will be along shortly, our resident A/C expert
        BUT I DON'T WANT A NEW CAR!
        1995 S2 Avant, Volcano Black
        • rj scotty
          • May 2006
          • 2195
          Beat Me too it
          Hello Johne
          And yes nobody's compressor will be kicking in at the moment
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            I've got:
            Opens - 1.45-1.6 bar
            Closes - 2.9-3.2 bar.
            SS
            • johne
              • Apr 2007
              • 1406
              8Kg!!! no wonder everyone complains the A/C weighs so much! It's actually around 1.3Kg, 3 tins iirc. I need to look the exact amount up.
              John
              • rj scotty
                • May 2006
                • 2195
                Could have made that up just something I remember the guy who filled mine telling me, 8 something or other.
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  Again I've got the 3B as having 1050g + 20g of R12. Not sure on the R134a though.
                  SS
                  • s2driveruk
                    • 12696
                    think its 750g for R134a but cant be sure
                    1992 3b S2 Coupe
                    • s2driveruk
                      • 12696
                      http://www.s2forum.com/forum/showthr...ghlight=aircon post 7 lists the gas fills
                      1992 3b S2 Coupe
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Audiman knows, and my air-con always worked really well, so that is good enough for me.
                        SS
                        • rj scotty
                          • May 2006
                          • 2195
                          perhaps it was 800g then. Oh well I was only 10X out
                          • Tonks4x4
                            • Nov 2005
                            • 3062
                            John
                            Thanks for that, is it 45psi with the pump running or stationary?
                            Where does it read the 4 degrees from? It was in a heated garage approximately 20 degrees.
                            Audi Nut!!!
                            • johne
                              • Apr 2007
                              • 1406
                              You need more than 3 bar pressure without the compressor running. That way, when you demand A/C the low pressure switch is closed and the compressor can energise. As the system cools down the pressure on the low side will fall and as it reaches 1.5 bar the low pressure switch opens causing the compressor to drop out allowing the system to warm up, pressure to rise back to 3 bar and the whole cycle starts again.
                              The "4 degrees" is read at the air intake just underneath the pollen filter and before the fan. On manual A/C cars it's a straight thermal switch that opens around 4 degrees cutting off the supply to the A/C relay. On climate controlled cars it's a NTC thermistor that the Climate Control Unit reads (along with the one in front of the radiator) to determine the outside temperature and stop the compressor activating.
                              John
