So my blower motor on the CQ is giving me a hard time. I swapped it to a B4 manual set up and it was working shortly after the swap. Over the course of time and with many trips behind the dashboard (for other reasons)one of the connections to the blower motor become un plugged. I didn't really care since it was almost summer and the car doesn't have A/C so no biggie. Now that it is cold I made an effort and removed the glove box and sure enough there was my power to the blower motor sitting unplugged. Plugged it in and reinstalled my glove box with a smug look on my face. Next morning rolls around and I got NOTHING! So now I'm confused. I checked fuses which were all fine. I removed the glove box again, everything was plugged in, i removed the ground wire and connected the blower motor directly to ground and turned the ignition to the on position and sure enough I get blower! It can't be controlled by the knobs but it is working, it doesn't seem to be at max speed but either the 2nd or 3rd position.
After lots of searching on the forums I found that the resister pack is a common failure, however the failure normally has a different set of problems, if it is the resister pack the blower motor still works when you turn the switch, but only works when in the 4th position. I'm leaning more towards a problem with the actual switch/knobs. Any other insight on this? Thanks!
