The interior fan has decided to only work on speed 4. This occured on the way back from Dougs house this week. I reckon its the resistor pack that has expired. Does anyone know where it is, to save me some time?
Inside fan only working on speed 4
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmTags: None
Can no one help me for a change??? LOLsigpic
Audi UR Quattro
****sigpic
Audi UR Quattro
Originally posted by sal_s2Not sure about 3b but on aby you can get to it by taking glove box out. Its mounted on the side of the plastic heater box thing, to the right if looking thru glove box.
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
Also the same as:
A80 87-92
Coupes up 8B-P-015 000
Golf 84-92
Passat 86-93
Corrado 89-95
or you could pop to your local main stealer and get one.
191 959 263 £22.31+VAT to the man on the street.
Benthe best intentions are fraught with disappointment - gil grissom
Cheers for the info. Will look into it tomorrow. Thanks againsigpic
Audi UR Quattro
A bit OT:
I took my fan out today and cleaned and lubricated it. It kept a bit of squeaking noise last winter when the weather was cold enough (-25C or so)
Just to tell you guys, in automatic aircon cars the fan is a complete PIA to take out as it's positioned horizonally vs vertical style in the non A/C cars. There is too little room to take it out. I had to loosen the dash and pull it quite a bit to make some room.
Btw the aicon style fan costs at the local dealer a pitiful 514 euros as the non A/C one 81€. Fair!Last edited by porkkis; 24 September 2004, 18:46.-
The fan itself is OK luckily, dont fancy taking that out at the moment. Will order a new resistor pack and that should sort it out.sigpic
Audi UR Quattro
Tom,
this is one of those muvver jobs, simple to do and a cow to get to here's the little SOB, arrowed:
£15.81+vat for the part.
Its like the fan motor, I have needed to change it for the last year, but it has always looked like a dash out job which can go take a long walk.....
Anyhow, if you undo all the left side dash bolts remove the left air vent and get your g/f or wife to pull on it as hard as they can (the dash!, the dash...) then you can just and I mean just pull the whole motor out of the case without breaking the dash!
That looks like a ****e job. Post back up here how to do it!
Originally posted by audimanThe fan itself is OK luckily, dont fancy taking that out at the moment. Will order a new resistor pack and that should sort it out.Attached FilesLast edited by Martynf; 26 September 2004, 20:43.
Your joking :'(
That looks a right mare to get at. It must be possible without removing the fan assembly??sigpic
Audi UR Quattro
they make it sounds oh so simple:Attached Files
Should only take 15 mins or so Can you order the part for me please. M chassis 3b with ACsigpic
Audi UR Quattro
