I have been reading up on related issues here but I thought that I should bounce this here and see what you guys think.
I will cut this story short and if you want the long story you can read up on Irry.com:
The short story is that I swapped a pipe, a hose and the compressor and got the system pressure tested and filled. And now when monitoring channel 52 and 53 on the OBD it tells me that the pressure is too low in the system. The symptom is that the compressor goes on and then goes off again in an endless cycle since it believes that the pressure it too low. When shortening the A/C compressor safety valve the compressor keeps running but there's not relly much cold to talk about. In the shop just after the system was filled up he measured 5.8 degrees Celsius in the center air vent but now it wont go down under 17.
As you all know the valve on the compressor is a bit hard for the workshops to fit their equipment on and the guys I turned to had the same problem. Eventually they managed to get a hose fastened but it wasn't a super tight fit and a "digital nose" used when looking for leaks detected gas where it connected to the valve. It didn't get better of that the seal in the hat for that valve in the compressor accidently pressed the pin in the valve for a good 30 minutes while I drove to my garage. The mechanic should have spotted this directly but for some reason he didn't and an unknown amount of gas leaked out. So these two things makes me draw the conclusion that the system isn't full. Hence that the warning I get in the OBD is correct and that the pressure is too low.
Anyone else have a few cents to spend on this?
Could it be something else? Faulty sensor or something?
So, I had already planned to replaced it and had a new one on shelf. I never managed to remove
