Hi guys, I have a problem with the A/C in RS2. It seems that climate control works perfectly but it does not send the order to compressor for working. If I give to the compressor 12V power from battery, it works perfectly and very soon we have +4C inside the car. Gas has been recharged so, it not a gas problem.
I have read all about Johne work, amaizing !! in my car exterior sensor is ok, inside ok,high pressure ok, low pressure?, I´m not sure.
After checking the climate digital codes ,shows following information
I do not understand what they means¿?¿?¿?
Thanks in advance and rgds
Code 52:
Code 53:
:I do not understand what they means¿?¿?¿?
Code 52:
Code 53:
. Maybe a Relay?¿?¿
