using digital B5 A4 parts on a/c system?
  • Sleeper_Avant
    • 2372
    does the later B5 A4 digital climate control interior stuff fit our B4`s?
    i.e the heaterbox with evaporator etc taken from a late model 1999 A4 with the later style digital display like this
    any help appreciated
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
    I wouldn't have though so the later ones used a dual zone system so i guess that means there are 5 flap motors? But maybe
    Don't forget the B4 climate swap still needs to use the B4 evap side of the heater box
    • Sleeper_Avant
      • 2372
      My A4 one is single zone Alex
      i will have a look intothis in depth i think, see if i can get it to work, i have my full A4 harness to use and im sure i could get it to work somehow lol
      im sure someone has done this before though? cant find evidence of it matey,
      will pop up after ive done it no doubt lol
      • targus
        • Sep 2012
        • 185
        • Home: United States Current: England
        get a picture of the back of a rs2/early a4/vw passat one and see if its the same, only pay attention to the brown plug section.
        • Sleeper_Avant
          • 2372
          early B5 item
          late B5 item
          • Sleeper_Avant
            • 2372
            pin counts/ plug configuration seem good
            • targus
              • Sep 2012
              • 185
              should be fine then. I know passat and a4 systems are the same so they just use one plug configuration for the lot.
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  That looks good. Let us know if it works. Even though I do like more the big screen of the b4 electronic climate
                  sent with WSGS3
                  • Sleeper_Avant
                    • 2372
                    schweet, although i will be fitting the later stuff, looks do-able!
                    will probebly do this when i get the A4 up on a Spit end of the month so i can move it about
                    cheers Alex
                    • Sleeper_Avant
                      • 2372
                      thats why i want to use the later stuff, i hate early B5 A4`s because of the jurassic looking switches and controls, the facelifted 1999> look so so much better IMO
                        haha, I like the early controls as they look classic now. The late 90s ones look the worst as they are old-modern and dated
                        • johne
                          • Apr 2007
                          • 1406
                          I believe that DCC will work with your A4 heaterbox and A4 fan speed control but you'll have to use a B4 evaporator. Keep the extra temperature sensors that are in the A4 outlets and move them over.
                          Difficulties you'll have to overcome will be the re-circ flap in you want to keep it operational.
                          The links Alex posted will help explain most things; I don't know how much changed (if anything) between the '98 model worked on in the thread and your '99 year.
                          I assume the lucar connector off to the side of the rear DCC connectors is for the HRW switch which has been added to the front panel of your DCC.
                          John
                          • Sleeper_Avant
                            • 2372
                            cool, cheers for that
                            will post back when i cannibalize my A4
                            Sean.
                            • johne
                              • Apr 2007
                              • 1406
                              Having another look at the photos it looks as though your unit has a raised part at the front top which could be the air inlet for the cabin temperature sensor and the silver item on the back the little fan motor for drawing air over the sensor........if this is the case that would be good because finding space for the sensor and motor is one of the pains you'll have to go through - but it could be bad because it could make the Climate controller unit too tall to fit in the S2 dash opening.
                              As I say can't be sure because I'm only going on your photos but something I suggest you check.
                              John
