I have a problem that’s developed overnight. The heater kicks out cold air only. All fan speeds work normally. My thermostat works ok I think- at least the temp gauge shows a normal rise in temp.
Is there anything I can check easily before going to seek help?
How do I check the rotary knob is working? Is there a diverter flap I need to check out? How? Where?
What else guys? Also any pointers to a simpleton’s guide to the parts and functioning of the heating system?
Looking at past threads Greg had a similar problem Oct 03. No info on how it ended though?
It’s one of those can’t wait problems as this morning’s heavy frost demonstrated. My joy on eventually getting past the frozen locks and door seals with a bucket of water changed to frustration and obscenities. Even more annoying as the water I’d sloshed on promptly added half an inch of ice to the windscreen. A can of de-icer will be a must for tomorrow morning. Does de-icer really damage plastic / rubber trim? It’s a rumour I’ve heard and I generally don’t use it.
Thanks guys
Nigel m ABY coupe
Thanks guys
Nigel m ABY coupe
