Do you mean the pipe connecting the compressor to the bottom part of the condenser unit? Just to make sure so any sellers will know which one. Sidrick might have had one but his is a 3b unit, don't know if they are the same.
I saw some second hand compressors on here a while ago, can't remember from who.
As rynaqui says, I've torn the AC out of mine (3B). It wasn't working before hand, but had no gas it, so I don't know what the issue was. Hence, I'd only want the cost of postage for any of the parts.
If you don't have means to test the parts before fitting/gassing then it might not be worth the risk.
i also have a complete 3b a/c removed minus the pipe trought the d/s wing, i cut that to get it out, everything bar the braket and the pipe through the wing, had no gas in when i got it, but he said it worked , "police officer" lol
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
