Hi
Had a slightly disturbing moment yesterday, Was accelerating when I heard a "pop" sound, looked in the rear view mirror and saw a big cloud of smoke
Was a few 100m from home so drove back slowly. No smoke anymore but high temp. Opened the bonnet/hood and coolant fluid was spilled in the firewall area. A closer look and I discovered the plastic thingy where the coolant sensor for the electronic climate control is installed was in 2 pieces.
The Q is: Coolant sensor for the ECC-what is it used for? I replaced the plastic thing with a SS pipe without the temperature sensor. Will the ECC demand a minimum temperature before the flap for the heating opens?
Will check if the plastic tube for installing temp sensor is still available tomorrow..
Was a few 100m from home so drove back slowly. No smoke anymore but high temp. Opened the bonnet/hood and coolant fluid was spilled in the firewall area. A closer look and I discovered the plastic thingy where the coolant sensor for the electronic climate control is installed was in 2 pieces.The Q is: Coolant sensor for the ECC-what is it used for? I replaced the plastic thing with a SS pipe without the temperature sensor. Will the ECC demand a minimum temperature before the flap for the heating opens?
