Air con removal
  • Air con removal
    So the latest breaker I have is fitted with air con
    Car is immobile so I can't take it anywhere to hav gas removed(if any in after all these years)
    Am I likely to poison myself or anything by just unbolting the lot?
    Don't want the mrs finding me collapsed in a heap on the floor or anything!
    What I did when I had to take the compressor off, was slowly opening one of the pipes, when I heard the gas coming out, I just left it for a bit to come out. And then it's all safe.
    '93 Audi UrS4 Avant LPG
      and if you get caught you will get a pretty big fine
        You wont get poisoned, just release one of the unions and get your hand out the way sharpish else will will get a dry burn from the refrigerant which is painful
        BUT I DON'T WANT A NEW CAR!
        1995 S2 Avant, Volcano Black
          That or wrap your hand before hand with a towel/cloth
          1996 S2 ABY Silver
            That's true.
            There are probably vans that can do it on the spot isn't there? If you want to do it properly
