Old Climate Problems
  • Simons
    • Jul 2007
    • 530
    • Country: Spain
    Hi,
    I have a problem with an old 3b climate, when you put the contact on, works, after 2 seconds die...no lights, nothing...if you put the contact off and on again, the same, 2 seconds working, the unit remember what you select the time before (if it was showing outside temp. starts again with outside temp.) and then nothing.
    I test the fuses and with another display unit and the same
    I take a look at the schematics and I don't know where is "J127", maybe it's under the dash, the unit who has the coloured vacumm hoses??
    Any ideas about the problem??
    P.D:Thanks s2central
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    Yes It is.
    • Simons
      • Jul 2007
      • 530
      • Country: Spain
      Thanks mate
      I have another clue...When the climate dies, the back light switch for fresh/recon air loses intensity
      • WidowmakerS2
        • Oct 2007
        • 354
        • Current: Norway
        Check the resistor unit ontop of the fan.
        If at first you don't succeed, destroy all evidence that you tried.
        -CQ 3b "S2".
        • Simons
          • Jul 2007
          • 530
          • Country: Spain
          ok mate, I'll check it
          • Simons
            • Jul 2007
            • 530
            • Country: Spain
            Finally was a bad ground, pin 7, I ground it with the radio cd and fixed
