ABY/ADU Aircon clutch/pulley removal.
  • K Simmonds
    • Dec 2007
    • 7633
    Anyone got any pointers on removing the clutch/pulley mechanism from the air-conditioning compressor?
    I have a good pulley kindly provided by Alex (nice one mate) but it's attached to a compressor in need of reconditioning, whereas the compressor on my car feels fine but the clutch in the pulley is shot.
    I'm guessing I need to make a puller of some sort, there are three M5 holes on the face of the pulley are these used to attach said removal tool?
    Obviously I've undo the M6 bolt in the middle and tried lightly tapping it etc, the 3B one (which I have a manual for) uses a puller but it's a completely different pump.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    Yes it sits on splines on the pump shaft, you need to make a puller to remove it
    I recommend soaking it in plusgas or similar for a while they are stubborn and the clutch assembly is quite fragile
    • K Simmonds
      • Dec 2007
      • 7633
      Cheers Alex, yeah it's had a good soaking in penetrating oil, I'll have a go at making a puller using the three holes on the front, defiantly don't want to force it so will take my time.
      I'd really like to get the air-con working before heading to Scotland at the end of the month and if the pulley sort's it I'll be chuffed, the rest of the system looks to be in good order and has obviously been maintained up until the car being taken off the road some years ago.
      Thanks again for the pump
      1994 MTM RS2.
      2000 B5 TQS.
        NPs
        • andy10v
          • 5996
          Originally posted by K Simmonds
          I'd really like to get the air-con working before heading to Scotland at the end of the month:
          Pretty optimistic about the weather are we?
          Sold ABY-stock
          • K Simmonds
            • Dec 2007
            • 7633
            , doesn't hurt to be positive. Should it be warm it would mean I could have the windows shut to protect myself from those wee flying menaces you guys have to live with up there.
            1994 MTM RS2.
            2000 B5 TQS.
              pint glasses?
              • K Simmonds
                • Dec 2007
                • 7633
                Originally posted by Error404
                pint glasses?
                Not planning on spending too much time in Glasgow so should be safe from flying glassware.
                The midges in the Highlands though are a blight and I want to able to retreat from them in my car. I may well be using it to sleep in for a couple of nights, Charlie and I are going to wing it and not book accommodation as it occurred to us today we have a mini camper van each.
                1994 MTM RS2.
                2000 B5 TQS.
                • K Simmonds
                  • Dec 2007
                  • 7633
                  Here's the unit I got from Alex with a good pulley, I've wasted an hour looking at it and can't decide how to go about making a puller.
                  An illustration of the factory tool would be awesome however some straight forward instructions would also be greatly appreciated.
                  1994 MTM RS2.
                  2000 B5 TQS.
                    When I removed one mate I used a normal puller and took the pulley off wholesale
                    • K Simmonds
                      • Dec 2007
                      • 7633
                      So you put the puller legs around the back of the lot and pushed on an M6 bolt wound into the end of the pump shaft? Will give it a careful go.
                      1994 MTM RS2.
                      2000 B5 TQS.
                        Yup, Pretty much, IIRC I used a washer to protect the end of the shaft
                        • K Simmonds
                          • Dec 2007
                          • 7633
                          After a fair amount of head scratching I managed to get the thing apart without damaging anything. I used an old bottom pulley with hole's drilled in it attached attached to the face of the assembly using the three M5 holes to enable me to remove it. Once I'd gotten the face of it was just a matter of removing two circlips before using a three legged puller to extract the centre which came off easily.
                          The bearing is in great condition and it's cleaned up well so hopefully I'll have working air conditioning soon, if the systems seems to be good I'll get it re-gassed straight away
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • sailaz
                            • Oct 2009
                            • 647
                            • Country: United Nations
                            nice job
                            but how this clutch suppose to work ? if system is empty does it have to kick in compressor by pressing button on climate control or it needs some minimum pressure to read from sensor ?
                            • K Simmonds
                              • Dec 2007
                              • 7633
                              Originally posted by sailaz
                              nice job
                              The electronic clutch is actuated by the non rotating circular part on the end of the pump itself with a single core wire going to it, I guess it simply works using magnetism. I hope these pic's of it loosely fitted back together help it make more sense.
                              Got the fun job of removing the old pulley assembly from the pump on the car.
                              The donated pump with all rotating parts removed.
                              The bearing/ pulley assembly slides on and is secured with two circlips.
                              The face plate which sit on splines and holds the lot together with an M6 bolt in the centre.
                              1994 MTM RS2.
                              2000 B5 TQS.
