Hello. Now when it starts to get hot outside i found out my climate controle doesn't work. It got 9 fault codes. I took out the controle unit to check if all the conectors where in place and they are and still no cooling. Are there a connector on the heater box in the car? Anyone got an idea where i should start?
9 Faults Found:
00799 - Coolant Temperature Sensor (G110)
30-10 - Open or Short to Plus - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
41-10 - Blocked or No Voltage - Intermittent
01272 - Positioning Motor for Central Flap (V70)
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
29-10 - Short to Ground - Intermittent
37-10 - Faulty - Intermittent
09-00 - Adaptation Limit Surpassed
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-00 - Blocked or No Voltage
01274 - Air Flow Flap Positioning Motor (V71)
9 Faults Found:
