Blower Motor Problem Fixed....thanks to JohnE
  • darkhorse1210
    • May 2010
    • 335
    Having scoured the forum for hours on this topic I came to the conclusion that there was no perfect solution to the squeaking/slow spinning blower motor.
    However, a PM to JohnE and everything started to make sense and this really is a straight forward fix once you can get the motor off.
    Step 1 - remove glove box
    Step 2 - remove all connections from blower motor
    Step 3 - remove screws holding blower motor in place (the last one at the top is the tricky one, it needs the dash dropping out slightly at the end to provide enough space to access it with a socket set.
    Step 4 - lube the motor at the bearings (front and back)
    Step 5 - test it whilst off the car and check it spins properly and runs on once the 12v power is cut off from it
    Step 6 - replace/reconnect everything beck up and test
    The result is that my blower works on all 4 settings and my aircon is once again restored.
    So no need for a £400 replacement from Audi a believe me there are no aftermarket ones out there, I have scoured the planet for one.
    Thanks John, I just hope I haven't dropped you I it now
    OP forgot to say it was a B4.
    • darkhorse1210
      • May 2010
      • 335
      Sorry, yeah.
      RHD RS2, air con version
        OP forgot to say that that was a temporary fix and that he will be going back and repeating those steps several times before he breaks down and buys an new blower with good bearings and unworn shaft.
          • 12431
          I've found a bit of silicone lubricant helps too
          • darkhorse1210
            • May 2010
            • 335
            Well, if it lasts a couple of years I'll be happy
              I'm guessing months but I am a pessimist regarding such things.
              Good luck.
              (Remember some parts are going NLA)
