when the climate control is on in my S2, in any setting (auto or manual) and regardless if it calls for A/C or not... am I missing something?
Turn the climate control off (fan to 0) and the rad fan shuts off as well.
Please help
www.quattro.ca
B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
I'm bored with it.
A/C compressor off (manual) and I put the climate control on 20ºC; the Rad Fan is OFF. But If I select more than this temp. >20ºC the Rad Fan turns ON and the coolant temp goes from around 85/91ºC to 80ºC or less.
I think than´s not normal, that isn't correct. True?
imho, it's not normal, the factory would not have designed it that way. Engine should retain a steady temperature once it warms up regardless of what accessories it's running.
I try with 2 modules, I try adjusting some values of internal controls etc. And nothing.
Firstly I thought if I reppaired with one chanel (don't remember who) adjust. Because at first, my fan turns ON with only 19ºC on the C. Control and last with 23ºC.
But some month later and battery recharge; now with 20ºC not, but with required 21ºC , the Fan already turns on.
And watter goes cooled and I colder (hahahahaha)
PS: I try, prove with non OEM thermostat and with 2 originals
Please help
Did you find the problem?
I was looking at some electrical diagrams but don't find what it could be.
is there a way to test the climate control panel for a good working?
