Heater Motor.. Again !
  • RS2junkie
    • Mar 2011
    • 409
    • Home: Ireland Current: Bahrain
    Hi,
    Looking for a bit of advice on electrics
    Had a new heater motor fitted but it stopped working again after a very short time. Took a look today and found the power and earth cables had been reversed at the connection to the motor ! (they are different sizes but its possible to switch them !!)
    Could this cause damage or will the motor just run in reverse. I assume it would just run backwards, or not run at all ??? I checked the motor is still spinning by accessing the pollen filter, and its spinning freely... I changed the thermal fuse on the resistor pack as I know this is the usual culprit, but nothing ....
    Any ideas on how to test what could be wrong ?
  • alexqts
    • Sep 2012
    • 92
    See this from SJM, it might help:
    I might see if my wires are reversed also, blower motor is vibrating like crazy and almost no airflow...
    Just seen that you're in Guildford, i'm near Weybridge - come to think about it, sure i've seen you around
    • LSG
      • May 2010
      • 898
      I guess you have changed the wires round to the unit. Maybe check if you have power on the live and the earth is an earth.
