EM problem
  • jogi730
    • 2335
    EM problem
    Went to have new downpipe made to accomodate new manifold (same as Mark H)
    Audi 90 quattro (Typ 85)
    20v turbo conversion
  • jogi730
    • 2335
    Old setup with RS2 EM
    • jogi730
      • 2335
      New mani fitted
      • jogi730
        • 2335
        Then put turbo on
        • jogi730
          • 2335
          Whooops... oh dear?
          • jogi730
            • 2335
            I was told this EM would definitely fit my car. HAve been in touch with supplier who has bent over backwards to do all he can to help. Lovely bit of kit and would recommend him to anyone considering a new EM despite my predicament.
            Need to cut into inner wing now. More modding needed than anticipated - isn't that always the way
            Chris
            • Billman
              • 4129
              From where is this manifold and how much did it cost? From what material is it made of?
              Go Holset or Go RS4
              • jogi730
                • 2335
                EM is made from thich gauge high pressure pipe (mild steel) as this apparently is more up to high output applications than SS. It was bought from a guy in Finland and cost 780 ( +20 Euros to have Exhaust gas measuring nut welded in) Euros including shipping.
                CHris
                  Whats happened to your old RS2 EM? :mischeif:
                  • jogi730
                    • 2335
                    RS2 EM is spoken for at the moment, although things might change as it has been adapted for Garrett turbo with internal wastegate. Gave it good looking over when came off the car and it does look to be in very good condition with no lacalised heating and no signs of cracks apparent.
                    If things change will let you know.
                    Chris
                    • gavs20v
                      • Sep 2004
                      • 3057
                      spoken for as in im having it
                      S2 Cabriolet.........
                      • Audi Parts Guru
                        • 1317
                        I personally wouldn't fit a manifold like this to my car if it required modding like this. Also, it doesn't look that well designed as the runners look to be quite long and subsequently this means that the turbo is a fair distance from the head resulting in possible fatigue due to the weight of the turbo and also of the fact that It's made of mild steel
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          I've seen a manifold like this in the flesh, I'd say it's a hefty piece of kit. Almost like a cast iron pipe with good wall thickness. I think the runners as short as they can be, whilst providing a good flow, and look almost equal length. Like most EMs there's normally a compromise somewhere. Also the collector is beautiful.
                          SS
                          • audiman
                            • 4827
                            mild is loads better than SS when used in the correct way. BTDT. As long as the turbo is supported then it will be fine. The only other way is to use expensive 321 SS, this is what jeffer has used.
                            Manifold looks great, i cant se any problems with the design apart from the inner wing bit, but hey thats tuning!! No pain, no gain IMO
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
                            • Dutch_RsBlueS2
                              • Sep 2003
                              • 285
                              Yep, the 321 SS will last
                              This manifold looks good though, i personally like the 321 SS better. But he thats just cos i`m using it myself to.
                              But would like to know how this if performing. And what kind of thermal coating is on the outside?
                              Is it sand, or glassblasted?
                              Cheers,
                              Cees
