Separate WG pipe
  • Sweeper
    • 1317
    • Country: Latvia
    Separate WG pipe
    Well , today I had a luck to drive my beauty . But I have a question to thouse who runs separate WG pipe (like me).
    When I drive it always pups from around 3000 RPM till 7000 RPM , it's sounds just like second exhaust. Pups all the way , not just on moment when i release pedal or hit the RED ZONE. It sounds great , but should it be this way ?
    P.S. I have RS2 engine full setup with custom cams and WITHOUT new map(just plain default S2 3B) , I also run S4 WGFV and S4 WG.
    Anyone ?
    Vadim.
    pups ?
    • Doug_RS2
      • 3847
      You do get a pulsing noise from it as soon as the boost spools up and the wastgate starts working.
      It can be loud.
      Try following a car with a wg pipe pointing to the ground - and see it throw up all the crap off the road.
      • Sweeper
        • 1317
        • Country: Latvia
        Doug : So it's normal it's trowing gasess all time ? It's just i thought it's happends not so frequent.
        Paul: Pups , bang , bah and s.o.
        Vadim.
        • Jeffer
          • 2057
          BTDT
          My car got sandblasted by following dougal.
          My car doesn't have the pulsing sound like yours doug. If I floor it it will open at around 4000 RPM. Thats mainly because of the stiffer WG spring. When its open theres no "pups" or whatever it maybe. Just serious loud noise from the WG.
          When I had the standard WG in it. The WG opend way earlier then now. It even opend at part throttle in lower rpms.
          RS2 Black - stock 315 HP
          RS2 RS blau - stock 315 HP
          Sport Quattro - 1005 HP
          High Octane website
          • Sweeper
            • 1317
            • Country: Latvia
            Ah , I'm one very happy chap . No phucking way it can be compared to my merc.
            And you should see the look of the pedastrians face when I was test driving S. And it look brutal without bumper and with large IC.
            Next stop is meet electirian to fix electrics , brake servo and meet the Chip Guru (Mihnea) in Belgium.
            Vadim.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              I don't have this problem following Doug, I can't get close enough when his WG is open.
              SS
              • Jeffer
                • 2057
                Haha, I was sitting on his bumper waiting for him to move over
                High Octane website
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  Try following Tom. He blows all the **** and animals out of the hedges and into your path.
                  SS
