Maf
  • s2-1.5bar
    • Sep 2004
    • 193
    • Home: Lithuania Current: United Kingdom
    Maf
    Hi Everybody,
    Anybody knows what MAF part numbers I can use on 3B apart from original 3b MAF?
    Andy
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by s2-1.5bar
    Hi Everybody,
    Andy
    Same numbers are on orginal AAN/ABY MAF. You cannot use other MAF without recalibration or ECU MAF table modification. If you have head on your shoulders and hose connected from turbo to WG (0.4 bar or less max boost) - you can use MAF from Opel, VR6, SAAB, bimmer, peugeot, whatever - for limp (not home) mode . Of course it means funny MPG and only around 90hp (C) Uu. But for me it's way better than limp home without MAF and temperature sensor.
    Right now I'm using BMW 850 MAF for limp-garage mode . Just because AAN MAF is installed in my 3B (daily driver) . That cost me incredible 10 euro and two days of thinking and experiments with calibration . Of course I had working MAF for example. Without it it's almost mission impossible.
    If you don't know what you are doing - "Kids - never do this at home"
    Sau
    • s2-1.5bar
      • Sep 2004
      • 193
      Thanx for advise.
      Aciu uz patarima(that in Lithuanian)
      Actually my current MAF works, its only can not take readings if I floor it. I got A/F meter so I can see whats going on in terms of mixture.
      I swaped Maf before, just to find where is the problem, and the mixture was OK with other MAF.
      Andrius
