Black Metal intake pipe
  • Black Metal intake pipe
    When i fitted my NOS kit, i made a small hole in this for the injector to be fitted... i'm now removing the kit as i never use it and need the money...
    Anyone have any ideas how i could plug this small hole that i've made so that i can drive the car normally...
    Ant
    2011 Kawasaki Z1000
    if its made out of alloy could you get it welded? i suppose i doesnt matter what metal its made of they all can be welded!!
      Stick a cut down bolt in it. Try drilling a trial hole in sommat else then when youve got the right size for the right bolt then drill out the black pipe to accomadate the bolt. Maybe try a bit of polyurathane sealant/adhesive sealant just to help keep it air tight. Or weld a patch on! Or slide a section of hose over it with two jubilee clips on?
      Money is everything! Second to Power of course!!! But money breeds power??
        Get a new one
        I think it is mild steel, so get it welded
        Nut and Bolt
        Silicon Hose over it with couple of jubilee clips.
        Go for a new one.
          They are not cheap by any means! ;-))
          Martyn
          www.vagparts.com
            unless you know the right people, eh?!
              A heve a spare new one
              Vadim.
                Out of choice would want an intact one, so 2nd hand etc... but will have to bodge in the mean time... the bolt option crossed my mind, but was v paranoid about the nut coming loose and ending up in the engine doing damage!
                Will prob go for weld or a patch and jubliee clips until i can sort something proper out, cos dont like bodging things
                Ant
                2011 Kawasaki Z1000
                  Its only mild steel so just weld it up. Its very thin, so have the welder turned down!!
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                    I'll get someone to do it... know just the person....
                    Tom..... whats ur rates for working on S2's.... might want some stuff done and seeing as you know what ur doing and a mechanic and on here might prove handy
                    Ant
                    2011 Kawasaki Z1000
                      Er, did you mention that "S", thats standard rate, divided by 0.1, -50.
                      I would love to do the work for you but, i am unable to do homers, family politics and all that *****.
                      But if you want to book through work its 34+VAT ph
                      Audi UR Quattro
                        S2 Ant . An just to warm you up. Isn't she sweet ?
                        But in your case of course I would go welding. Much cheaper indeed and not expensive.
                        Vadim.
                          if you can live without it send it me..i will weld it in such a way you will not know its ever had a hole.
                          You pay shipping both ways and give me enough for 3 pints at my local.
                          let me know
