my new dump valve
  • Chris5044
    • Feb 2005
    • 1663
    my new dump valve
    just got this dv from forge its the FMDV006C
    (006)
    it seems a little large ... especially the connections...
    is this a straight swap for my standard?
    • 12431
    yup it should be
    • Ski
      • 2591
      dumpvalve got binned and i replaced with original. I was recommended S3.
      What is the difference? between original, s3 and the above?
      ABY Coupe
        (006)
        Good choice mate, straight swap that one.
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          can someone pinpoint what is the difference between OEM and aftermarket dumb valves?
          thanks
          Vasilis
          • BRY
            • 3755
            You can replace parts in an aftermarket dump valve, usually.
            • Nuvo
              • Nov 2003
              • 3827
              The afternarket items have renewable di'aphragms, the OEM items are cheaper. That's the two key differences I remember being mentioned before anyway.
              Nuvo.
              • Jas11n
                • 5067
                The likes of Forge, bailey, AMD and Milltek's aftermarket recirc DV's have a piston valve inside, instead of a diaphragm
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                • Ski
                  • 2591
                  any noise difference? performance difference?
                  ABY Coupe
                  • Nuvo
                    • Nov 2003
                    • 3827
                    Doh! You're right, Jas, that's what I meant to say.
