Pictures of RS2 vs Stock EM
  • PeterS
    • 426
    Folks:
    I've seen photos before, but of course I can't find them now.
    How can one visaully confirm that an RS2 EM is installed vs a stock 3B/ABY one?
    Thanks!
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
  • BRY
    • 3755
    RS2 upside down
    • BRY
      • 3755
      RS2
      S2
      1 and 5 have a different route on the RS2
      Sorry bout the first pic
      • Jon441cc
        • Dec 2005
        • 2061
        S2
        RS2
        • PeterS
          • 426
          Bry:
          It also looks like the RS2 has more external "ribs" or cast lines?
          -peter
          Peter S
          1991 Coupe Quattro
          1991 Coupe Quattro
          1995 S6 Sedan
          1995 S6 Wagon
          • BRY
            • 3755
            Originally posted by PeterS
            Bry:
            -peter
            Looks that way, but the main difference is the route of the gases to the turbo for 1 and 5.
            • PeterS
              • 426
              Bry:
              Understand that, but if you are looking at an installed EM and turbo in a car, you cannot necessarily see all that much of the EM - typically just the top of it around the WG, and a little from the side, correct?
              Put it this way, if someone claims to have an RS2 EM installed on their car, whats the easiest way of verifying it ? :-)
              Peter S
              1991 Coupe Quattro
              1991 Coupe Quattro
              1995 S6 Sedan
              1995 S6 Wagon
                • 12431
                yes it does have more ribs because the standard S2 manifold has 2 cylinders join into pipe to wastegate and then the main exhaust where as the RS2 manifold has them all join together and then split to wastegate and turbo
                • PeterS
                  • 426
                  so is this an RS2 EM & Turbo?
                  Is this an RS2 EM & turbo?
                  Peter S
                  1991 Coupe Quattro
                  1991 Coupe Quattro
                  1995 S6 Sedan
                  1995 S6 Wagon
                  • PeterS
                    • 426
                    another picture
                    another view
                    Peter S
                    1991 Coupe Quattro
                    1991 Coupe Quattro
                    1995 S6 Sedan
                    1995 S6 Wagon
                    • ridgeracer
                      • 189
                      • Country: Norway
                      that was pictures of a RS2 manifold..
                      96 RS2
                      94 urS4
                      02 ALLROAD
                      • PeterS
                        • 426
                        hard to tell but does the turbo look like a K24 or RS2?
                        Peter S
                        1991 Coupe Quattro
                        1991 Coupe Quattro
                        1995 S6 Sedan
                        1995 S6 Wagon
                          Impossible for me to tell from those pictures. You would need to get the wastegate off for a proper look... and looking for right part numbers on the turbo is probably sufficient - unless someone is going to lengths to hoodwink you with wrong internals - which you'd never guess from external examination anyway !
                          Paul
                          • Doug_RS2
                            • 3847
                            It is an RS2 EM - but has S2 EM studs on it - It will have had one of the studs shortened on top and 3 on the bottom shortened so that it fits on - IIRC. It should have RS2 studs all round if the work has been done properly - tut tut!
