exhaust route??
  • missmouse
    • 296
    exhaust route??
    Having read a few posts on this subject & I need new system, I am interested in the actual routing of these uprated systems (some at over 3")
    The standard thing is so tight over the driveshaft I am really keen to find out where the big bore pipes go????!
    simon
  • Pisobiker
    • 1175
    Simon you're right,
    fitting a 3" pipe around rear right axlearm is a very tight job but still possible.
    I did my system myself and the work turned to be pretty good. Some contact with chassis only very seldom on bumps, holes or stuff like that (I also have a pretty stiff suspension configuration).
    Anyway the job wasn't easy, expecially because I had to work most of the time layed under the car (didn't have the ramps at the moment).
    Marco
    • Vagsport
      • 533
      Anything larger than 3" will need to be custom built on the car, that way at least it will clear the o/s/r driveshaft and the sides of the tunnel.
      Siena
