Ok,
I have been reading the different forums, S2forum, AudiWorld, and etc. for a while.
What makes the RS2 EM better than the S2 EM?
I have read that the 1 & 5 exhaust have more heat in the S2 when you start boosting the power.
Does the RS2 have larger diameter runners? Is this why the studs have to be shortened when you install it on a S2, AAN, or ABY motor?
Or do the studs have to shortened because the runners run closer to the head?
Is the collector larger, in order to except the RS2 turbo?
What makes the RS2 EM better?
They are both cast, does the RS2 EM have the same cracking problems as the S2?
Anyone done one out of stainless? Not the long tube ones, but just matching an RS2 manifold.
Thank you,
Thank you,
OOOO
