Intake manifolds and larger intercoolers...who's running what?
  • NoNonsense
    Forum Sponsor
    • Apr 2004
    • 673
    Hey guys,
    I'm trying to do a poll here, although I don't know if it will actually work. I am curious how many of you are running larger front mount intercoolers and which intake manifold are you using? Those of you who have something in the works, please speak up, too!
    What would be ideal for your set-up?
    Thanks!
    28
    Larger intercooler and standard intake manifold
    32.14%
    9
    Larger intercooler and AAN intake manifold
    10.71%
    3
    Larger intercooler and front-mounted-throttle-bodied manifold (ie MTM)
    42.86%
    12
    Stock setup
    14.29%
    4
    The poll is expired.
    Joe "NoNonsense"
    axis motorsport
    joe@axismotorsport.com
  • Technogym
    • Dec 2004
    • 200
    • Country: Norway
    He He!
    Off course my solution is not listed as an alternative!
    I run a bigger IC and a bigger custom build IM with the TB in the same pos as stock! This due to my rad for the AC. A/F ratio gets a little high in rush traffic, but in normal speeds and above everything looks fine on the computer.
    Well, so far so good for an 515BHP setup, we will see this summer if it can take a little increase in boost...
    Vegard
      • 12431
      I have a large IC to fit, but not on yet. Also looking at fitting a reverser IM at same time.
      • martinjs
        • 3205
        Mine has larger i/c (600x300 core) 63mm intake pipe throughout, stock 3b inlet though. No extra lag. Big drop in intake temps during mapping (RS2 Turbo)
        • BRY
          • 3755
          Where would you class the RS2 IC?
          It's larger than the "standard", depending on what car you started with
          • NoNonsense
            Forum Sponsor
            • Apr 2004
            • 673
            ah yes, that should fall under larger intercooler with standard intake manifold.
            What have you done for cross-member, Bry?
            Joe "NoNonsense"
            axis motorsport
            • elijahallens2
              • Aug 2004
              • 310
              I did a 24x12x3 FMIC and Dahlback intake manifold.
              Elijah
              91 Audi Coupe Quattro- AAN engine transplant
              • NoNonsense
                Forum Sponsor
                • Apr 2004
                • 673
                B-e-a-utiful! ;-)
                Joe "NoNonsense"
                axis motorsport
                • Mark Halligan
                  • 2001
                  24x12x3 IC, self made dual plenum IM with 80mm TB (Holley Mustang).
                  Ran the whole set up for a few hundred miles and it all went OK. Engine out for replacement now, so I'll test it some more when the new motor is in.
                  Mark - Modded
                  • NoNonsense
                    Forum Sponsor
                    • Apr 2004
                    • 673
                    Thanks, Mark!
                    Joe "NoNonsense"
                    axis motorsport
