anybody using pyrometer?
  • anybody using pyrometer?
    what should be the exhaust heat?
    fahrenheit - celcius?
    thnx
    Quattro
    Depends where you mount the thermo couple
      planning to install at the end of down pipe,under the car
      Quattro
        Hmm, well its nice and easy to mount one infront of lamda just after turbo
        or u can do what i did and mount in the manifold.
        the temp across the turbo should be about a 100 degree C drop
          what does xtra hi-temp mean on pyro?
          thnx for help
          Quattro
            thnx for help
            That means your turbo has just melted and exited the back of the car :wacked:
            I'm sure 850degrees Celsius/Centigrade is the max limit before damage can occur - this is after the turbo in the downpipe. So there is'n much point having a guage that goes upto 2000 degrees C
            I need one as well - it's an easy way to see if something is wrong or about to go wrong - Lee definitely needs one
              link to pyrometer
              may be this helps
              Quattro
                Looks good to me. I think I will get the autometer one - although one with a warning buzzer might be useful.
                  you can do a search on that web-site; much cheaper then demon tweeks (where i used to buy before)
                  Quattro
