Losing fuel pressure
  • jade
    • Jan 2005
    • 1811
    Hi to all
    I have a rs2 the car runs well normally , but when i turn it of i lose fuel pressure in the fuel rail
    i have had the injectors checked & they are fine not leaking , what else could it be , is there a non return valve
    Any ideas of why it could be losing pressure would be helpful many thanks
    Cheers Jade
    RS 2 580HP
  • volcano rs
    • Jun 2005
    • 2265
    probably a faulty fuel pressure regulator
    • pastures16
      • 2058
      does it restart ok when cold but when warm its a bitch
      turns over a fair few times before it fires and when it does it misfires for a few seconds
      94 s2 avant
      aoc member 1116
      • jade
        • Jan 2005
        • 1811
        Cold start in the morning not that good have to crank her a bit then she fires but takes a moment to catch on all cylinders ( just changed water senser in back of head for ecu temp) when warm just have to crank a fair bit then starts . i think just to get pressure up
        Cheers Jade
        RS 2 580HP
        • jade
          • Jan 2005
          • 1811
          Changed fuel regulator today no change
          Cheers Jade
          RS 2 580HP
