Tired of booming exhaust at cruising speed
I want to make a back box with 2 entry tube and 2 out put tube
-First One 50mm tube with bafle inside
-Second One 76 mm tube straight through with ATP valve at the entry.
the ATP valve is opening with turbo pressure so that before 7 PSI or what ever you set it for the exhaust will go through the 50 mm tube and above through the 76 mm tube. like this you got two system in one.
I know Fujitsubo do one like that called "legalis viable" this for subaru but it's very expansive + have to adapte to RS2
I'm working in Thailand 2 week every 5week so could make it their as stainless building is very cheap if some intrest could make a small production for RS2/S2 avant
