open air filter---> cold air supply......
  • Quattro_Vaassen
    • Dec 2005
    • 23
    hi,
    does anyone have pictures of how they made the cold air box/heat shield for an open air filter. i bought one of A`PEXi for mij S2 (ABY) and i was wondering how it`s done best.
    and what kind of material is the best to use?
    the cold air supply is already there because it`s an ABY.
    pictures please, so i can get an idea
    thnx & greetz,
    Erik
    Life`s too short to go slow!!!!
  • Jeffer
    • 2057
    Erik,
    Perform a search on the forum. There are loads of pictures with open airfilters on the s2. Usually with 2 x 90 degree bends and some sfs hose.
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    • Quattro_Vaassen
      • Dec 2005
      • 23
      Jeffer,
      of course.......
      i`ll see what i can find.
      greetz Erik
      • stevieyid
        • Apr 2005
        • 2251
        Post a link if u find something interesting. I have an apexi with 2 90 degree bends but i need to make a heat shield and make a cold air feed
        • Quattro_Vaassen
          • Dec 2005
          • 23
          hi,
          i will!!
          a friend of mine is willing to make a custom stainless steel box for me, if it`s ready i will post some pics.
          that same friend told me to be carefull with too much hot air. it could make some damage to your engine. (don`t know why..) so i put back the org. airfilterbox till the heatshield is made. ( i loved the woosh-sound...)
          greetz Erik
            Hot air shouldn't damage the engine as factory (and good aftermarket) chip programming will reduce advance and boost at high air temps. So much so you might notice it running sluggish with excessive intake temps...
            Paul
            • s2_southwest
              • Oct 2004
              • 823
              search : http://www.s2forum.com/forum/showthr...light=cold+air
              Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
