Diy air filter jobby
  • s2avant95M
    • 1217
    • Home: England Current: United States
    whats the question m8?
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
    • terrybullwon
      • Mar 2006
      • 8782
      What do you think about my results, ie sound, noise.
      Chef
      • ericd
        • Nov 2003
        • 1240
        had a quickshift filter installed for a year now (just got round to buying some cleaner for it ..), don't see too many others fiited amongst S2's at the moment
        • s2avant95M
          • 1217
          i had a Dahlback kit with K&N cone filter, same kind of noises came from mine. got fed up with it in the end, RS2 airbox for me now, much, much better IMHO.
          Tim
          • QuattroFever
            • May 2006
            • 1360
            Hi,
            did you buy this filter as a kit or is that all your own handywork? Fancy a quikshift myself!
            Volcano ABY coupe
            Ant
            • porkkis
              • 1994
              Where can I find that kind of hose? Needed for a different application, but would be just great!
              • Ross
                • Aug 2005
                • 3399
                Hey good stuff!! I've got a K&N cone filter. You wanna hear it good 'n' proper, lift the bonnet and (when the engine is warm of course) give a stab on the throttle to take it about 6k+ rpm... some guy wanted t hear my engine once at the pub, he jumped back about 6 feet and made a comment about nearly getting sucking in
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Yeah lol,
                  Thats spot on, mines terrible.......... :mischeif: :mischeif: :mischeif: sucked a few saxos and any thing thats as lite as a wheel barrow.
                  QuattroFever
                  Made it my self, if enough people want the hose i might be able to get some more.
                  Chef
                    Ruby red owners think alike!
                    • QuattroFever
                      • May 2006
                      • 1360
                      I wouldn't mind getting one of those alloy pipes to connect my filter like eric and s2_bo's.
                      I was thinking of using 90mm (or closest) 90 degree long radius stainless steel welded pipe bends 1.5 - 2.0mm thick. Cut to length mark the angle and weld them together. Need to source the bends.
                      Filter is ordered and in the post!!! Cone D Quikshift with trumpet (needs modifying, the trumpet outlet size is only 75mm I want 88mm same as MAF.
                      Volcano ABY coupe
                      Ant
                      • ericd
                        • Nov 2003
                        • 1240
                        From memory, the Dtype cone is the largest (200mm ?), so I'm guessing you're gonna have to have it rear facing , cause with any pipework your gonna have space issues trying to point it forwards to the nearside h/light. I think all previous versions of the quikshift have been type C (please correct me if I'm mistaken , ) but the type D is good for up to 500hp+
                        also with reference to the maf and (the trumpet outlet/reducer) connection are you sure the MAF is 88mm ?
                        HTH
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          i have the largest cone and its front facing, its fine. i am pretty sure its the D to.
                          Chef
                          • QuattroFever
                            • May 2006
                            • 1360
                            HTH
                            __________________
                            Eric
                            1996 - Ming Blue Pearl - Nothelle n300
                            That's right. The cone D is rated to over 500hp at 200mm x 175mm it's HUGE!!! I didn't realise how big it actually was.
                            I had a measure up with various objects trying to picture the size. I got some strange looks whilst standing measuring and gazing at a plantpot in B&Q.
                            Ahem!
                            I've got it temporarily fitted with a peice of ribbed hose off a dehumidifier at work!!
                            Sounds Great!!!
                            It's possible to have it front facing but it's tucked right up close to the inner wing. It looks tight but i'm going to try to find a way. I'll post a pic once it's sorted.
                            I'm sure when I measured the maf it was 88mm diameter outlet.
                            _____________________________
                            Quattrofever
                            Volcano ABY coupe
                            Ant
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              Heres a picture of mine in, its front facing. A flower pot YES does sound very nice
                              Chef
                              • QuattroFever
                                • May 2006
                                • 1360
                                Thats the badboy!
                                Top bit of kit!
                                I haven't got a heatshield on mine yet!
                                With any luck it'll be on this weekend!! when your rolling it's not bad. Just when you hit traffic.
                                ___________________
                                Quattrofever
                                Volcano ABY coupe
                                Ant
