Exhaust Tapping Noise
  • NICNAC
    • Oct 2003
    • 104
    I have noticed a little tapping noise on the rear end of the car when biting the clutch around 2000Rpm or under,
    so i jacked the car up for a better look and found 'tie raps' around the exhaust rubber mountings
    the Exhaust is hitting the diff as circled in the pics.......
    Has anyone else ever had these symptons?
    If so, is it a case of the exhaust mountings being knacked and needing replaced or the bushes on the Diff/Rear Subframe needing renewed
    Or could it be a poor quality Replacement Exhaust?
    i now Fancy going for that S/S exhaust mentioned in the other thread (£210euros)
    Anyone any ideas
    Steve.
  • NICNAC
    • Oct 2003
    • 104
    exhaust clamps.....
    • NICNAC
      • Oct 2003
      • 104
      And tie raps
      • Mihnea
        • 1288
        Steve: tie wraps are a very good solution against ageing rubber hangers, as it prevents them from becoming loose and letting the exhaust bang wherever it can (although yours does already).
        HTH,
        Mihnea
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
          The proper hangers on a UR-quattro exhaust system are steel links surrounded by rubber. Never tried fitting them on an S2 system - nor do I know if the proper S2 items are also re-inforced like this.
          Paul
          • Martynf
            • 1885
            ar those good old chain encased in rubber mounts, they were the business!! alas audi in the infinite wisdom dropped them about 2 years ago which was a real shame as they were soooo strong!! but they were also sooo expensive!
            Martyn
            www.vagparts.com
            • NICNAC
              • Oct 2003
              • 104
              is this a normal thing then?, Could i just buy poly bushes or standard ones to replace the tie rapped ones?
              Has anyone else had this problem before????
              Steve.
              • Ski
                • 2591
                My heatsheild on exhaust rattles upto 3rd gear past 4k rpm?
                dosnt bother me but pple give me weired looks when im just kicking into my turbo.. been told some liquid metal glue thingie would do it rather than a weld job... does anyone know where this is located and if a normal jack job can get me there? i cant find it!
                ABY Coupe
                • Jeffer
                  • 2057
                  Hi Steve,
                  My exhaust was also resting on the reardriveshaft. I still haven't found what causes this interference. My solution to this was: undo the three bolts to the rearsilenser connection, and I tie-rapped it really tight on the rubber. Then I tightened the three bolts again. And as we say in dutch (translated) "child can do the laundry!" Piece of cake.
                  cheers,
                  Jeffry
                  RS2 Black - stock 315 HP
                  RS2 RS blau - stock 315 HP
                  Sport Quattro - 1005 HP
                  High Octane website
                  • NICNAC
                    • Oct 2003
                    • 104
                    thanks Jeffer,
                    I'll have a go at this tomorrow afternoon
                    because tonight it's time
                    Steve.
                    Might be getting one of these exhaust soon........They're only 210 Euros:eek2:
                    cutom auto craft, custom universal and audi stainless steel exhaust systems
                    • Ski
                      • 2591
                      whats the in £££ ? considering it myself!
                      ABY Coupe
                      • Mihnea
                        • 1288
                        I haven't tested them yet but I know for a fact that an exhaust is critical on turbo motors. This guy's turbo exhausts seem to be the same as NA ones, which means that if they have any performance increase over the stock NA exhaust, then it means that you'll lose performance with a turbo engine.
                        What you want with a turbo engine is as little backpressure as possible, and the exact contrary on a NA engine...
                        HTH,
                        Mihnea
                        Originally posted by NICNAC
                        thanks Jeffer,
                        Steve.
                        http://homepage.internet.lu/customau...xhaust_sys.htm
                        www.MRCTuning.com
                        info@MRCTuning.com
                        Workshop Directions
                        • NICNAC
                          • Oct 2003
                          • 104
                          211euros + 20.11euros (what i was quoted postage to Lake district area)
                          Backbox only though,
                          Converts to £159 using:
                          But dont know yet about whether VAT, Import Tax, etc is applicable
                          Steve.
                          • Vagsport
                            • 533
                            Loosing to much back pressure can be detrimental to the oil seals of the turbo. You don't want a smoker :eek2:
                            Siena
