Yeah I have to agree, there is a trade off to be had. If you want that much HP it is going to be high up the rev range with a much narrower powerband than the stock. Allbeit alot more power in the power band.
It is always going to be a trade off, if you want the car for 1/4 mile and track driving it may be suitable but day to day you will probably want something that spools sooner.
You could look at a stroker which wont rev as much but will have a better torque characteristic.
i have gt30r on my car i am using .82a/r hotside. i have serious power from 4500rpm.
i used .63a/r hotside. serious power comes from 3700rpm but 50hp less on high rpm.
now i go back to.63 a/r hotside. much better on street.
Any power graphs with both turbine options? I have a 30R with both housings, but which to use on stock bottom end? Im thinking the larger may be better to reduce torque and so stop rod bending???
