Experimental collector.
  • jonn48
    • Mar 2014
    • 92
    • Country: Russian Federation
    As an experiment, I decided to make an exhaust manifold, retaining the stock air filter. Here's what happened. It did not work to check the operation at full load, as 24 7400 broke.
  • SteveH
    • 4460
    Looks like the turbo has seen better days. The compressor wheel is all corroded.
    91 Modded 3B
    14 A6 Avant Black Edition
    • ThatGUY
      • Sep 2004
      • 794
      So what happened? It looks like a cool idea.
      The turbo failure was not caused by the new exhaust manifold was it?
      //-\\ ((_)) //)) //
      • jonn48
        • Mar 2014
        • 92
        It seems that the turbine was stored in a humid room, and as SteveH wrote above, corrosion appeared. I will temporarily put k24 7000, while 24 7400 will be under repair.
        • SteveH
          • 4460
          Did you check the compressor side before running it with the new manifold? It looks like some of the missing pieces have been gone for some time, as the crack lines are already corroded.
          91 Modded 3B
          • jonn48
            • Mar 2014
            • 92
            Yes, I opened the compressor housing. The compressor wheel was intact, but with corrosion. Perhaps it already had cracks that were invisible.
            • david1980
              • May 2014
              • 1028
              manifold looks like an interesting design
