Oil inside ISV.
  • ristokru
    • Oct 2016
    • 270
    Oil inside ISV.
    Hello,
    is it normal that i found oil in ISV valve? Looks like more is from intake large pipe if i but finger to pipe side. IM side dont have so much oili surface.
  • steve briance
    • Aug 2014
    • 1455
    How much oil? Condensing engine breathing vapours used to coat the inside of my ISV on my 7a.
    • ristokru
      • Oct 2016
      • 270
      Lets say finger is covered with black oil. With what you cleaned ISV? WD-40 is bad as some people have told.
      • steve briance
        • Aug 2014
        • 1455
        It doesn't sound too bad what you describe.
        If you use carburettor cleaner and blast out really well it will improve how it works. Be careful with cleaning with a tool but it might help to use a bit of cotton wool on a stick to rub away thicker layers. More carb cleaner, more cotton wool and repeat until clean.
        • Bowie69
          • Nov 2013
          • 2681
          Yep, nothing to worry about, air flow is rather slow through it, and closed when throttle is open, so oil just sits there accumulating.
          • ristokru
            • Oct 2016
            • 270
            I dont have in my arsenal Carb cleaner. Is contact cleaner also ok to use? I have also apc car detailing cleaners etc.
            • steve briance
              • Aug 2014
              • 1455
              I guess contact cleaner would be o.k as it is a solvent. Degreaser would also work to remove oil but carb cleaner seems better at removing stubborn carbon deposits. The problem with wd40 is that it doesn't evaporate and very quickly, dirt sticks to it.
              • SteveH
                • 4460
                WD40 or similar light oil works
                91 Modded 3B
                14 A6 Avant Black Edition
