Has anyone fitted these if so what length and what would I need it’s for a coupe
Braided fuel lines
I intend on fitting new hard lines under my car, using anodised 9.5mm aluminium tubing ending in AN fittings.
It's a little different on mine as I will be using a surge tank in the rear and an aftermarket pressure regulator, with flexible braided line either end. But, If the rest of your fuel system is stock then you could do a similar thing with yours by replicating the factory lines and (I believe) the NPT fittings.
Jase.Last edited by Jaswan; 23 January 2021, 16:10.Comment
