Between the turbo and the base of the down-pipe where the Y pipe then connects, is there anything connecting it to the body? The family album shows a bracket but i don't remember ever seeing one. As the 15mm bolt is refusing to come off the turbo/down-pipe stud…
I need to know i can just remove the engine with the downpipe attached. Figure i will need to potentially drop the front subframe to get the whole lot out too.
thanks!
I need to know i can just remove the engine with the downpipe attached. Figure i will need to potentially drop the front subframe to get the whole lot out too.thanks!
