I have a suspected hole in the gasket (sounds like a tractor), it's only just started and cant see any evidance of a hole but it's not the easyst of things to look at! so it looks like i will have to take everything off to find the hole!
Do I have to replace all the gaskets that have to come off or not?
It is good practice to replace all the gaskets you remove so so get a perfect seal when you bolt it all back together
You dont want to put it all back together then have to take it apart for a another gasket
