Fuel pressure regulator AAN
  • igor136
    • Jun 2014
    • 363
    • Country: Croatia
    Hello guys. The fuel pressure regulator on my S6 died. PN 0280160516. It had a gasoline leak on the vacuum line. I bought a new one but with a different Bosch number. PN0280160575. The guy at the store said it is a new number. When I removed the old one, I noticed that the fuel hole was twice as thin. Is this good, does anyone have experience? The car starts, runs, but...
    Poslano sa mog SM-A135F koristeći Tapatalk
  • 5cylinderman
    • Oct 2011
    • 367
    I had the same same problem building a Cobra replica a few years ago. I would be very wary using it, especially if you have an uprated fuel pump. I doubt that regulator has the flow capacity to return enough fuel back to the tank, so unless your fuel pump has an internal pressure relief valve I reckon you're in trouble.
    I sourced a Weber Alpha regulator from Burtons in England which had the correct the larger internal diameter.
    • igor136
      • Jun 2014
      • 363
      • Country: Croatia
      The fuel regulator behaves well. Operating pressure is fine. But after turning off the car, I have a problem of a sudden drop in fuel pressure. I bought a new Pierburg fuel pump. Now the fuel pressure does not drop quickly, but after one hour the pressure drops to zero. I took the fuel injectors out today, no leaks. It's dry under the car. Is it possible that the non-return valve on the new pump is faulty?
      1-2-4-5-3
      • igor136
        • Jun 2014
        • 363
        • Country: Croatia
        Hello guys. Today I measured the drop in fuel pressure towards the pump. The pressure drop was 1 bar after half an hour. That's not bad. Question, is the fuel pressure regulator closed when the car is turned off?
        1-2-4-5-3
