Finally has a chance to do a little bit on the S2 today since it has been neglected for the past month after fixing the cam cover gasket it developed a boost leak.
Went out there today and found it was the pipe from the inlet pipe to turbo to the cam cover.
So took it all apart and re fitted the pipe and went out for a spin and was running lovely, got 3/4 way home and on boost above .8 bar was getting psssshhh
Its too dark to go and try again now so I think I will have to fabricate a new bit of pipe work with a bigger lip on it and see if I can get some stronger hose clips. Any suggestions? they are the smaller 20-25mm clips. At least it happened after surprising an S4 & TT
