Try nylon cable ties. Having spent a long time using (relatively) expensive small jubilee clips and experimenting ( I have the time ) with both; Cable ties - done up tight, are far better, and easier to fit and less prone to leak. I'm using 200 x 2.5mm size. Silicone hose - i.d. 3mm.
Idle vacuum and overrun vacuum are points higher on my vacuum/boost gauge and the car feels faster from less indicated boost (standard aby engine @ 120K).
( Dont hit me Jamo).
i can see it now, one of B&Q's gormless staff comes over to you and asks.
